Community Member
MeetingPlace 6.0 Outdial Problem
I have tried everything to get MeetingPlace to outdial but to no avail. I have attached the GW log and the trace from MP. MP accepts calls and you can create/join/listen to any conferences.
Community Member
Re: MeetingPlace 6.0 Outdial Problem
Just to let you know I tried the #31 call from a IP Phone in the MP conference and I still can't outdial. cptrace lists RetCode 3171 and 3107. Everything is working with MeetingPlace except for the outdial. I will rate 5 for any helpful posts.
Community Member
Mystery solved.
I reaccomplished the gateways, rebooted the CallManager and everything works.
Community Member
editted...noticed you fixed the solution.
188
