Mobile and Remote Access via Expressway - Question regarding Expressway-E Licenses
Hello.
I'm in trouble with the Express way E license option Key.
I recived a pak related LIC-EXP-E-PAK.
it contains a lot of option key like TURN, Advanced Networking and so on.
I notice that the Expressway C when you upload the right option license key change the name displayed in the web page, i expect the same change on the Expressway E but i'm wrong.
Can someone clarify about this option license key?
I just tryng to deploy the two virtula machine for mobile and remote access and i think the edge is not working due to a license problem.
1 ACCEPTED SOLUTION
When you fulfil your LIC-EXP
When you fulfil your LIC-EXP-E-PAK, you should get a quanity of 2 for EXP-SERIES and EXP-GW. You take 1 of these quantities and apply it to C. Fulfill the rest of the PAK (AN, SERIES, GW, TURN & E) and apply it to E.
Reboot both devices and they should correctly display Expressway on the webpage.
Sean
1 REPLY
Sean
136
