Community Member
Mobile Voice Access(MVA) problem
Hi Guys,
I based on the administrator guide to setup the mobile voice access features in my cucm7, but it's not work, when I dialed the number from outside, I hear "Your call cannot be completed as dial..." I summary the steps below, please check anything is missing or wrong, thanks for your help.
1. Create a remote destination number(RDN)
2. Create a remote destination profile(RDP) and associate with the RDN
3. Create a user, enable mobile voice access and select the RDP
4. Enable the Enterprise feature Access and Mobile Voice Access in service parameter
5. Configure the Mobile Access DN(520)
6. Configure the voice gateway
   application
    service mva http://cucm_ip:8080/ccmivr/pages/IVRMainpage.vxml
   dial-peer voice 10 pots
    service mva
    incoming called-number 520
    direct-inward-dial
   dial-peer voice 20 voip
    destionation-pattern 5..
    session target ipv4:cucm_ip
    dtmf-relay h245-alphanumeric
    codec g711ulaw
Community Member
Hi Kam,
I have the same issue, did you had any response or do you found the way to skip this issue?
Thanks in advanced for your help..!!
Fernando Vazquez
Hall of Fame Super Silver
If you are hearing the same annunciator, that means CUCM is not configured properly for routing. Ensure the CSS applied to the GW can reach the MVA number. Debug isdn q931 would show this as number unassigned.
Chris
Community Member
Hi Chris,
I've cheked the CSS assigned to the GW and contains the PT assigned to the MVA number. Any other though?
Are the Mobility service parameters configured properly, i.e.
Is Enable Voice Access set to True
Is Mobile Voice Access Number configured under service parameter?
What is Inbound Calling Search Space for Remote Destination  set to?
Chris
Community Member
The Enable Voice ACcess is set to True
Mobile Voice Acces Number it is configured under service parameter
the CSS for Remote Destination is CSS_COS_1_noFAC which includes PT_Phones, this is the Partition assigned to MVA Number.
I'd like to attach a file, where explains all the problem.But since this is not my discussin not able to do it, I already open a discussion, the name for the discussion is "MVA cannot establish the call"
https://supportforums.cisco.com/thread/2152701
1992
