09-06-2007 08:09 AM - edited 03-18-2019 07:47 PM
a few phonse are showing mwi lights but after clearing messages the light will remain on. How do I clear the lights? Thanks
(Unity 3.1)
Solved! Go to Solution.
09-06-2007 12:31 PM
Hi Kelley,
Ginger has given you some great info here,as always, (5 points for this detailed answer Ginger :)
The Message Lamp on the phone is usually associated with the main line (Line button 1) on the Telephone, so if you Press line button 1 and dial the MWI OFF number (like 2600 in my first example) the Red lamp will extinguish.
Hope this helps!
Rob
09-06-2007 09:30 AM
Hi Kelley,
In CCM look up the MW-Off number (Feature>Voicemail>Message Waiting>Directory Number>Message Waiting Indicator Off )
This will be a Directory Number like perhaps 2600. Go to the phone, press the Line button, dial 2600 and the MWI Lamp/Icon will turn off.
Hope this helps!
Rob
09-06-2007 11:39 AM
There are two Directory Numbers one is ON and one is OFF... should both be on?
09-06-2007 12:20 PM
Hi -
In addition to what Rob mentioned, you can also look up the MWI on and off extensions in Unity. On your Unity server, go to Start - Programs - Unity - Manage Integrations. Select your CCM integration by clicking on the name (below Properties)and go to MWI tab. If the phone light is ON, you can dial the MWI off extension to turn the light off. If the phone light is OFF, you can dial the MWI on extension to turn the light ON (most users complain when the light doesn't turn off however). To resolve some of these problems, you can resynch MWI from the Unity server nightly and schedule this to occur sometime during the evening, when no users are using the system. Click on the Properties of the integration and you'll see the MWI Synchronization for this integration check box. The AvNotifier service resynchs the MWI and sets the appropriate lamp instruction to the phones according to unread voice messages in the users' inboxes.
Ginger
09-06-2007 12:31 PM
Hi Kelley,
Hope this helps!
Rob
09-07-2007 06:26 AM
it worked....had all the phones dial in to set to off. thanks!
09-07-2007 06:31 AM
Ginger - I don't have MManage integrations under Start - Programs - Unity - only intgeration monitor.
09-07-2007 09:50 AM
Hi -
Glad to hear you got this working! Saw you are running 3.1 - The Manage Integration may be specific to 4.X ... I forget. However, check in Unity Tools Depot on your server's desktop. Click this and drill down to Switch Integration Tools. You should see Telephone Integration Manager. This is the same thing. You can double-click this and it opens the CallManager integration windows.
Ginger
09-07-2007 10:49 AM
Ginger - thx for response....I am under Tools Depot\Switch Integration Tools and only thing is Port status Monitor..missing?
