need help - CME configuration
Hi there,
Need your expertise. This is my first time to set up CME. What we have here, 1 router cisco 3945 (CME installed) and 10 router cisco 2901 (remote device). Phone connected in the main (3945 router) is getting registration  but remote IP phone connected to 2901 router is just getting IP address only all other configuration are not installed in the IP Phone.
Your quick feedback is highly appreciated.
Re: need help - CME configuration
Hi Junska
If you are trying to achieve Remote Teleworker Solution, then have a look at the constraints defined in following url:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1061320
Regards..
Hi Mdawar,
Thank you and appreciate your quick response. Can you sort it out a simple configuration just for testing environment, In my Cisco 3945 CME was installed connected with one (1) ephone and in the remote branches I am using 2901 router with one (1) ephone. Is there any other configuration in 2901 router aside from ip helper-address (pointing to CME). In cisco 3945 (CME) when you plugged any phone, its registering and it works but in 2901 router (remote branches), when you plugged any device (phone) ONLY ip address assigned and its not working.
Please drop me a simple configuration and Thank you in advance.
Regards.
325
