12-15-2013 03:02 AM - edited 03-19-2019 07:39 AM
Hi All;
I want to share something with you and need your help. currently we are using 6.0.1.2000-3 version and want to shift to cucm 9.0.
I have the new licenses with me. its a UCS BE6K machine.
Can i import Bulk Administration Backup - CSV file into cucm 9.0 in order to register phone. I cannot manually enter phones its 800 extensions.
Please guide me the right upgradation step i will be very thankful to all.
waiting for your prompt reply.
Regards.
Solved! Go to Solution.
12-24-2013 12:25 PM
All 6.1 versions are downloadable from here:
HTH, please rate all useful posts!
Chris
12-15-2013 07:48 AM
No, the import/export feature works only on the same version, so you need to first upgrade your system. Similar questions have been asked many times here, with Drive to 9 you can go to version 6.1.5 and then upgrade on new hardware.
HTH,
Chris
12-18-2013 02:15 AM
Dear Mr. Chris;
I really appreciate your reply. I checked with the following link for right upgrade:
Our version is not listed as it is engineering version : 6.0.1.2000-3 not base version. I am worried which path i should chose for call manager migration on UCS.
I have doubt may be license issue could be occur , Please suggest me for easiest way....
12-18-2013 06:22 AM
Upgrade to 6.1.5 first on current hardware.
Chris
12-18-2013 10:13 PM
Dear Mr. Chris;
Before direct upgrade on current hardware , can i first test it on test virtual machine with same mac address on separate network.
I am afraid to do on live machine. and really thanks alot for your suggestion. I will update you once done or comes any problem during upgrade.
12-19-2013 05:52 AM
Hi Muhammad,
Since it looks like that you would be installing CUCM version 6.1.5 on vmware and then upgrading to version 9.x, you would require using the jump upgrade procedure as documented in the following link
https://supportforums.cisco.com/docs/DOC-35163
Manish
12-22-2013 02:07 AM
Hi Manish;
where i can download cucm 6.1.5 upgrade version ? i checked on cisco downloads but
couldnt find out please help....
i will first upgrade from 6.0.1.2000-4 to 6.1.5 ........
12-24-2013 12:25 PM
Chris
12-19-2013 06:11 AM
You could, but that would not be supported as Drive9 requires specific versions, it does not mean it would not work, though I've seen many posts on troubles with installing some versions in vmware.
HTH,
Chris
12-24-2013 11:00 PM
Thanks alot chris for helping ....
12-26-2013 12:43 AM
Hi Muhammad,
Please remember that you cannot upgrade directly t0 6.1.5 from 6.0.1. You will first need to upgrade to 6.1.2 version, then upgrade to 6.1.3 and then to 6.1.5. There is no direct upgrade from 6.1.2 to 6.1.5. Please check the software compatibility matrix for details
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Manish
12-26-2013 03:11 AM
Dear Mr. Manish:
Thanks for your reply. Mr. Manish I have to ask before starting the process it seems to me that a long procedure. let me tell me more things.
1. we have 680 extensions
2. using phone models: 7940 and 7911 series.
3. current cucm version: 6.0.1.2000-3
how i can export license file from cucm version: 6.0.1.2000-3 what is the procedure.
Secondly, what you suggest me either go with jump upgrade or fresh installation and enter all phones manually. we dont need downtime because current cucm is in production enviroment.
I ask all experts kindly tell me the best way to follow as i am junior in voice field.
12-26-2013 03:20 AM
Hi Muhammad,
There are no license implications for upgrade from 6.0.x to 6.1.5. Jump upgrade is a good option as you will be able to build 6.1.5 on vmware and upgrade to 9.x directly from there. If you do not want to follow the three step upgrade from 6.0 to 6.1.5 then you should build 6.1.5 and enter all configuration manually. if it is ok for you then you can go ahead with the same.
Manish
12-26-2013 03:25 AM
Dear Manish;
till 6.1.5 i have to follow jump upgrade then can perform direct upgrade from 6.1.5 to 9.0. Is it correct ?
12-26-2013 03:34 AM
Upgrade from 6.1.5 to 9.x would be jump upgrade and it is possible. Upgrade from 6.0.x to 6.1.5 is a normal cucm upgrade.
Manish
