Need help on callmanager 4.1
Need to call the customer and check whether they have changed the (fans/powersup
Dear Friends I want to know how to find how many license is used in the call manager 4.1. is there any way to find out how many licnese is used? where to see how to see?
Gem
Re: Need help on callmanager 4.1
the concept of license and/or DLUs is for linux appliances 5.x and 6.x, not for windows versions
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Javalenc. So For ccm 4.1, we can use any number of devices.There must be restriction or how many device that ccm can support. Because you must be knowing, deach device have some weightage ( some unit). pls explain
regards
gem
yes there is, but is not based on licensing which was your original question.
Table 8-2 Maximum Number of Devices per Server Platform
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/4x/42clproc.html#wp1083641
javalenc
java
83
