Need help on set up CUPC at home
At home, I have a desktop, Vista, USB Logictech headset H390, DSL to Internet
At work, I have a desktop, XP with CUPC  V7.0, installed and working fine with all calls.
At home, I use  VPN, connected to my desk top XP at work.  Run CPUC on work PC, received incoming call but at home, on headset, I hear no sound, caller does not hear anything either.
Please, help me to set up. Thanks
1 ACCEPTED SOLUTION
From here http://www.cisco.com/cisco/software/release.html?mdfid=280455801&flowid=5461&softwareid=282074306&os=Windows&release=7.1(1a)&relind=AVAILABLE&rellifecycle=&reltype=all
Please note, you need to register & configure your home CUPC in your CUCM/CUPS. Registering just your work CUPC wont get your home CUPC working.
GP.
Pls rate helpful posts !!
Need help on set up CPUC at home
Viett,
When you say you connect to Work using VPN, how do you access your work desktop from home ? i.e. using VNC, remote desktop etc ?
If that is the case, it wont work like that. You wont be able to hear/speak to phone calls using remote desktop sessions. You can just perform actions ( answer/drop calls etc ) but voice will not traverse to your home like that. You need to have the CUPC installed in your home PC too.
GP.
Hi GP,
Plaese, let me know where can I download CUPC 7.0.1. Could not find it.
GP.
Thanks for your help.
366
