Need help with router-switch connection
New at this: I've 2501 routers. How do I connect these routers to a switch or a pc in a production environment. I used the rollover and serial cables to configured the routers but I'm stuck connecting ethernet between the routers and pc or switch. (Note: my routers each has one AUI, 2 serial , one console, and one AUX.) I believe I need to use the AUI cable on the AUI port. I may need a cable with 15-pins on one end and RJ-45 at the other end. Is this right?
Re: Need help with router-switch connection
You probably want to ask this over in one of the Network Infastructure forums - this boards if for questions about the Unity messaging system products...
You need an AUI/UTP transceiver, its an active device that converts AUI 15 pin to UTP RJ45 connection. They cost about $40.
233
