Need reference of CCME on cisco 2821
Hello;
I have a router cisco2821-sec/k9 and I want to install the CCME (Cisco Call Manager Express) with 40 users  license
What is the reference (to purchase) of the  CCME software with 40 users  license for the router cisco2821-sec/k9
The IP phone CP-521SG and CP-524SG  can operate with a CCME installed on the Cisco 2821?
If not what kinds of the most cheap cisco IP phone can operate with a CCME installed on the Cisco 2821 router
Thank you in advance
Hall of Fame Super Red
Re: Need reference of CCME on cisco 2821
Hi There,
When you purchase a CME feature License (to implement CME) it is based on the number of users and includes the appropriate user Licenses.For example, if you were setting up an office with 40 users you might order;
FL-CCME-48
Which would leave you room to expand by 8 new people somewhere down the road.
The 500 series of phones are NOT supported on CME, so the next well-priced model suggestion
might be the 7931
7931 Data Sheet
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps7062/product_data_sheet0900aecd80534259.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
what dou you think about 7911G and 7912G
Which most chiper ip phone is adapted for the standard ?
I want to use 20 7911G, 10 7912G  and 10 7931G
Hi there,
The 7912G has been announced as "End of Sale" "End of Life", so probably not the best choice (see attached)
EoS and EoL for Cisco Unified IP Phone 7912G
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_eol_notice0900aecd80538042.html
You probably want to go with the 7911G, which is the Cisco recommended replacement model.
http://www.cisco.com/en/US/products/ps6565/index.html
Cheers!
Rob
Hi will buy FL-CCME-48 for my cisco 2821 ,  5 ip phone 7945G and 30 ip phone 7911G
Do I need 5 CP-7945G-CCME or 5 CP-7945G should be OK ?
That depends on licensing. The phone models are identical. The -CCME version has a licensing component. If you already have licenses you should be good to go. If you have licenses from a CUCM install, you may still be good to go but would have to dance with your Cisco AM to get it worked out.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Finally I choose to buy this element in the table
I already have the router cisco2821-sec/k9 and one cisco switch poe
Please the system will work or do I need additional requirement ?
Reference
Quantity
FL-CCME-48
01
VIC2-4FXO
01
7945G
05
7911G
25
773
