Personal Speed dial not show on 7931
After added speed dial at cme but phone 7931 can't show the number under directory personal speed dial.
How to show the speed dial number on 7931 phone.
1 REPLY
Silver
Re: Personal Speed dial not show on 7931
The phone user guide gives instructions on how a user might assign their own speed dials, if it is allowed - it does not say when that might be, and we did not try it, but here is the part in the guide that discusses it:
Program Personal Speed-Dial Buttons
Your system administrator can assign speed dial numbers to your phone. You may not be able to program every speed dial number.
To program personal speed-dial buttons, use the following method:
1. Select an available phone line by lifting the handset, by pressing the NewCall soft key, or by pressing a line button. Listen for the dial tone.
2. Press the pound key (#).
3. Press the speed-dial button that you want to program. A short beep confirms that you are starting to program this button.
4. Enter the speed-dial number. The digits appear on the phone display. Use the backspace (<<) soft key to erase digits that were entered incorrectly.
To remove a speed-dial number without replacing it with a new one, press the pound key (#).
5. Press the same speed-dial button a second time to indicate that you have finished entering the speed-dial digits and to store the new speed-dial number.
6. To continue, press a new speed-dial button and repeat the process. Hang up the handset to finish.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/ip_phones/7931/4.0/english/user/guide/ugKSsccp.html#wp38541
141
