Community Member
PIMG and AvayG3 going to wrong mailbox
I have a Unity 4.2(1) system that is integrated with call manager 4.1.3 and with an Avaya G3r via pimg units. This system is in a testing phase and not all Avaya and VoIP users are on this new system.
Everything seems to be working properly with the exception when an Avaya user calls another Avaya user where both parties are on the Unity platform and the call rolls to voicemail. When this happens Unity will send call to the CALLING party's voicemail and will prompt for their password.
When I look at the call logs on the PIMG units, I see both the calling and called party numbers, with the calling party number listed first.
Keep in mind that if a Avaya subscriber that does not have a Unity mailbox calls an Avaya aubscriber that does have a Unity mailbox everything works fine.
Any suggestions will be greatly appreciated.
Robert Luechtefeld
1 ACCEPTED SOLUTION
Re: PIMG and AvayG3 going to wrong mailbox
Sounds like Unity does not understand the calls coming in from the PIMG. You can watch the call viewer on Unity to see the calls coming in live. They will show you what the call type was "fwd, ring no answer" etc. This will give you an idea of what the Avaya switch is sending the PIMG. PIMG may be thinking that it was a direct call to Unity which is why you are getting the "please enter your password" greeting after 4 rings to voicemail. Check to see how Unity handles Direct Calls and Fwd Calls in SA. You could have something out of order on this page also.
Also, this is common, check to see that your Subscribers are homed into the correct Integration. IF your Avaya subscriber had VM, they should be on the PIMG integration, not CCM. Check their Profile page near the bottom for "Integration".
Bronze
are you emulating a 7434ND ??
Community Member
The stations in the hunt group on the Avaya are set for 7405ND, which is a numeric display phone also. For some reason, the PBX won't accept a 7435ND.
Community Member
I worked with the Avaya admin this morning and we now have the hunt group stations set for 7434ND. The problem is still occuring.
I've captured the SIP messages between the PIMG and the Unity server. I captured the SIP Invite on one of the failing calls. Station 1210 is the calling part and station 1253 is the Called party. Here is the SIP portion of that capture
Session Initiation Protocol
Request-Line: INVITE sip:1131@192.168.39.35:5060;Transport=udp SIP/2.0
Method: INVITE
Resent Packet: False
Message Header
From:"1210"<1210>;user=phone;vnd.pimg.port=2;tag=2AD3324631353641002752BF
SIP Display info: "1210"
SIP from address: sip:1210@192.168.39.27:5060
SIP tag: 2AD3324631353641002752BF
To:"1131"<1131>
SIP Display info: "1131"
SIP to address: sip:1131@192.168.39.35:5060
Content-Type:application/sdp
Diversion: <1253> ;reason=no-answer
Call-ID:01B22AFB3C81400000005B8A@pbxgw.default.com
CSeq:1 INVITE
Allow-Events:refer,message-summary
Expires:120
Via:SIP/2.0/UDP 192.168.39.27:5060
Contact:<1210>
Contact Binding: <1210>
URI: <1210>
SIP contact address: sip:1210@192.168.39.27:5060
User-Agent:PBX-IP Media Gateway
Max-Forwards:70
Supported:100rel,timer,replaces
Content-Length:294
Community Member
Thanks for the response. This pointed us in the right direction to solve the problem.
A rule created for an earlier problem was in the wrong place in the routing.
249
