Community Member
Please help me need drivers
Folks,
I have a 7825-H1 server, i am unable to load windows 2000 on it for unity install as the install fails (no hard drives found).
Please could someone tell me from where i can get the raid drivers?
Green
Re: Please help me need drivers
Are you using the PCD (Platform Configuration Disk)?
Its the one ship with Unity (Orange envelope)
You didn't give the specs for the hardware. If you are using the windows 2000 server cd, then you either need
HP Embedded SATA RAID Controller Driver for Windows 2000/Windows Server 2003
or
HP ProLiant Smart Array 5x and 6x Controller Driver for Windows 2000/Server 2003
from
http://h18023.www1.hp.com/support/files/server/us/locate/20_6053.html#18
100
