Presence integration with Sametime
I have a CUCM v6.1.2 & CUP 6.0 that I want to integrate with Sametime v7.5.1. The integration I need to implement is click to call & presence functionality. I have successfully configured the click to call functionality, but I am having some issues with the presence integration. The error message I see in the sametime client is "Login failed". It seems like the presence server can not authenticate the user credentials.
It's not clear to me where users are provisioned at Presence server. I'm trying to authenticate using username/password configured in CUCM.
Is this correct or do I need to integrate with an LDAP server?
Thank you in advance.
  • Unified Communications Applications
Red
Re: Presence integration with Sametime
The best way to verify the username/password is to use CUPS user page -
http://ip-address-of-CUPS/ccmuser
You should use the same username/password for your plugin.
My blog:
http://htluo.blogspot.com/
My book:
http://www.lulu.com/content/5552336
Michael
Thanks for your reply Michael. I use the same username/password for both plugin & CUPS user page. I can login to the user page but not through sametime. Any idea why?
Red
If that's the case, it could due to "Digest Credential" was not configured on CUCM > User Management > End User page.
You may bypass Digest Credential check by going to CUPS Admin > Cisco Unified Presence > Proxy Server > Incoming ACL. Create a 'all' ACL there.
Michael
Hi Michael,
I have added the access lists as you suggested and now the user can login to the presence server. But still the client can not "see" the presence server.
In the "Cisco Unified Server (Presence)" section I see the following:
Server:
Port: 5060
Domain: nbg.gr
Status: Error - connection timeout
Any idea why the "server" field is empty?
Evi
Red
1) On "Troubleshooting" tab,"Enable detailed logging"
2) Exit and re-launch Sametime
3) Go to "Troubelshoooting" tab. Create Problem report.
4) Attach problem report here. We'll take a look.
Michael
Michael,
I have attached the log file. Thanks a lot for your help.
Red
Per the logs, ST plug-in received presence info. But it failed to map that presence into to ST user.
In Domino directory, the user ID part of the email, does it match the user ID on CUCM?
Yes, they match.
Red
CUPS/CUCM's user IDs are case sensitive. do they match exactly with ST?
426
