12-02-2011 07:17 AM - edited 03-19-2019 04:03 AM
CUP: 8.5.1.10000-35
CUPC client 8.5.4 installed on Windows XP and Windows 7
I have noticed after installing CUPC 8.5.4 on a few computers that when a user logs into the client I get the below RTMT alerts from the presence server. I do not notice any issues with functionality of the client. I have dug through the logs, but nothing stood out as to what is causing the flood of messages. Is anyone else seeing this or have a suggestion on how to avoid these alerts.
At Fri Dec 02 09:56:34 EST 2011 on node presence, the following SyslogSeverityMatchFound events generated:
SeverityMatch : Alert
MatchedEvent : Dec 2 09:56:11 presence syslog 1 nbslogpd[12639]: 18 messages were dropped
AppID : Cisco Syslog Agent
ClusterID :
NodeID : presence
TimeStamp : Fri Dec 02 09:56:11 EST 2011
12-07-2011 04:05 PM
Hi Sean,
This is a known cosmetic defect
CSCtj94754
You should not worry about the alerts.
Christos
01-30-2012 11:46 AM
I am running CUPS 8.6.3 and am seeing these messages today. In looking at the bug, it is indicated as fixed in 8.6(0.97000.45). Is it fixed or is it still an issue?
03-19-2012 08:45 AM
I had the same issue on my system when I had UP XCP router traces set to debug. I changed back to the default info setting to resolve. Check your alarm and traces settings to verify default settings are enabled.
