Problem changing greetings in unity connection in bulk edit mode.
I have problems changing greetings in bulk edit mode for existing users, about 800.
I select all users-->bulk edit-->edit-->greetings-->standard-->greeting enable with no end data, my personal recording-->recordings-->select language-->play record-->open file, upload file and save. After this I test the greeting and works well.
The strange problem is that next day the uploaded greeting is not played, instead the system default greeting is played. I have tested several times in several days with the same behaviour. If I upload the prompt separately to an user the new prompt persists next days as it expected.
Unity Version 9.1.2.10000-10.
Silver
Hello jlcembellin,
Check replication (if it is a cluster),ntp and cores via CLI:
utils dbreplication runtimestate
utils ntp status
utils core active list
Replication should reflect a (2) the link below should help you recognize the Replication state between the nodes:
https://supportforums.cisco.com/docs/DOC-13672#Checking_Current_Replication_
NTP should be stratum 4 or below.
Any cores showing up during the timeframe the issue occurs.
Also check through RTMT (Real Time Monitoring Tool) the application logs to see if there is any event related.
-You are updating 800 users at once, if you do with less let's say 13 can it be reproduced?
-Do you have any locales (languages) installed?
-The account you use to do the changes is it the default admin account or a custom admin account, if using a custom one such as account with Tech, HelpDesk, Greeting, Audio Text roles or any other double check using the Default admin account to perform the bulk edit update.
-Also does the issue reoccur if the recording is done via the TUI (Telephone User Interface) and not uploaded?
David  |>∋(K
Hi David, thanks for your answer.
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
DB CLI Status: No other dbreplication CLI is running...
Cluster Replication State: BROADCAST SYNC Completed on 1 servers at: 2013-10-01-16-41
     Last Sync Result: SYNC COMPLETED  603 tables sync'ed out of 603
     Sync Errors: NO ERRORS
DB Version: ccm9_1_2_10000_28
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from MAD01-CUC-01 (2 Servers):
                         PING        CDR Server    REPL. DBver&  REPL. REPLICATION SETUP
SERVER-NAME IP ADDRESS   (msec) RPC? (ID) & STATUS  QUEUE TABLES  LOOP? (RTMT) & details
MAD01-CUC-01 172.17.0.35 0.093 Yes (2)  Connected  0   match Yes   (2) PUB Setup Completed
MAD01-CUC-02 172.17.1.35 0.798 Yes (3)  Connected  0   match Yes   (2) Setup Completed
admin:
[Kadmin:utils dbreplication runtimestate
MAD01-CUC-01 172.17.0.35 0.037 Yes (2)  Connected  0   match Yes   (2) PUB Setup Completed
MAD01-CUC-02 172.17.1.35 0.706 Yes (3)  Connected  0   match Yes   (2) Setup Completed
admin:utils ntp status
ntpd (pid 29473) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*192.168.1.16    192.168.101.4    4 u  736 1024  377    0.443  -19.323   5.288
synchronised to NTP server (192.168.1.16) at stratum 5
   time correct to within 430 ms
   polling server every 1024 s
Current time in UTC is : Fri Dec 27 07:57:50 UTC 2013
Current time in Europe/Madrid is : Fri Dec 27 08:57:50 CET 2013
admin:utils core active list
No core files found
The deployment is with spanish locale. No problems changing the greeting with TUI. The account is the admin default account.
340
