Problem Installing Visco Microphone VT Advantage Camera II
Everything seems to work fine although I get the error message as indicated in the attached Screen Captured File.
Version is 2.0.2.0
Re: Problem Installing Visco Microphone VT Advantage Camera II
My suggestion would be to update all Chipset drivers for your motherboard. I also hate to ask a dumb question but you did install the VT adv. software before you plugged that camera in right?
Yes I installed the S/W before I plugged the Camera.
Then the only other sugestion would be to update all chipset drivers. Outside of that try wiping the install and starting from scratch. Other than that I doubt I could help you.
229
