Community Member
Problem whit cisco 2921 + EVM-HD-8FXS/DID whit CUCM
Hello everyone.
I have the following problem that I am not able to resolve. I define a new connection BRI.
I can make calls seamlessly between the Cisco Unified Communications Manager (version: 8.5.1.10000-26) and Cisco 2921 (CISCO2921-V/K9).
But when you receive calls from BRI Cisco receives the call but the Cisco Unified Communications Manager does not tranfere for Ext
And I can not understand why. In other BRI interfaces do not have this problem.
This configuration here that I'm using.
Current configuration : 17238 bytes
! Last configuration change at 18:02:34 PORT Mon Apr 2 2012 by admin
! NVRAM config last updated at 18:02:56 PORT Mon Apr 2 2012 by admin
version 15.1
hostname  <<omitted>>
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5  <<omitted>>
aaa new-model
aaa authentication login default none
aaa authentication login <<omitted>>
aaa accounting connection h323 start-stop group radius
aaa session-id common
clock timezone PORT 0 0
clock summer-time PORT recurring last Sun Mar 1:00 last Sun Oct 1:00
network-clock-participate slot 1
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 BRI0/0/0
network-clock-select 2 BRI0/1/0
network-clock-select 3 BRI0/2/0
network-clock-select 4 BRI0/3/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name  <<omitted>>
isdn switch-type basic-net3
crypto pki trustpoint TP-self-signed- <<omitted>>
enrollment selfsigned
subject-name cn= <<omitted>>
revocation-check none
rsakeypair TP-self-signed- <<omitted>>
crypto pki certificate chain  <<omitted>>
<<omitted>>
      quit
voice-card 0
dsp services dspfarm
voice call send-alert
voice call disc-pi-off
voice call carrier capacity active
voice rtp send-recv
voice service voip
no ip address trusted authenticate
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 5
voice translation-rule 1
rule 1 /^21 <<omitted>>/ /21 <<omitted>>/
rule 2 /^21 <<omitted>>/ /21 <<omitted>>/
rule 3 /^21 <<omitted>>/ /21 <<omitted>>/
voice translation-rule 2
rule 4 /^21 <<omitted>>/ /21 <<omitted>>/
rule 5 /^21 <<omitted>>/ /21 <<omitted>>/
rule 6 /^21 <<omitted>>/ /21 <<omitted>>/
voice translation-rule 3
voice translation-rule 4
rule 1 /^0/ /400/
rule 2 /^/ /21 <<omitted>>/
voice translation-rule 5
voice translation-rule 11
rule 1 /.*/ /21 <<omitted>>/
voice translation-rule 12
rule 2 /.*/ /21 <<omitted>>/
voice translation-rule 13
voice translation-rule 14
voice translation-rule 15
rule 1 /.*/ /21<<omitted>>/
voice translation-rule 21
rule 1 /^./ /0&/
voice translation-rule 22
rule 1 /^./ /0&/
voice translation-rule 25
rule 1 /^./ /0&/
voice translation-rule 23
rule 1 /^./ /0&/
voice translation-rule 24
rule 1 /^./ /0&/
voice translation-rule 32
rule 1 /^212104974/ /21 <<omitted>>/
rule 2 /.*/ /212104975/
voice translation-profile INLINE_EMPA
translate calling 22
translate called 2
voice translation-profile INLINE_EMPB
translate calling 23
translate called 3
voice translation-profile INLINE_EMPC
translate calling 25
translate called 5
voice translation-profile INLINE_EMPE
translate calling 24
translate called 4
voice translation-profile INLINE_EMPD
translate calling 21
translate called 1
voice translation-profile OUTLINE_EMPA
translate calling 12
voice translation-profile OUTLINE_EMPA_NT_FAX
translate calling 32
voice translation-profile OUTLINE_EMPB
translate calling 13
voice translation-profile OUTLINE_EMPC
translate calling 15
voice translation-profile OUTLINE_EMPE
translate calling 14
voice translation-profile OUTLINE_EMPD
translate calling 11
license udi pid CISCO2921/K9 sn  <<omitted>>
hw-module pvdm 0/0
hw-module sm 1
username admin privilege 15 password 0  <<omitted>>
redundancy
ip ssh time-out 60
ip ssh authentication-retries 2
class-map match-all Voz
match access-group 100
policy-map QoS
class Voz
  priority 200
  set precedence 5
class class-default
  fair-queue
gw-accounting aaa
attribute acct-session-id overloaded
acct-template callhistory-detail
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address  <<omitted>> 255.255.0.0
ip access-group BLOCK in
load-interval 30
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr  <<omitted>>
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
description  EMPD N:
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/0/1
description Ecotel EMPD N:
no ip address
isdn static-tei 0
interface BRI0/1/0
description  EMPA N:
no ip address
isdn tei-negotiation first-call
isdn static-tei 0
interface BRI0/1/1
description  EMPA N:
no ip address
isdn tei-negotiation preserve
isdn static-tei 0
interface BRI0/2/0
description  EMPB N:
no ip address
isdn static-tei 0
interface BRI0/2/1
description  Ecotel EMPB N:
no ip address
isdn send-alerting
isdn sending-complete
isdn static-tei 0
interface BRI0/3/0
description  EMPE N:
no ip address
isdn static-tei 0
interface BRI0/3/1
description  Ecotel EMPA N
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/0
description B EMPC N:
no ip address
isdn static-tei 0
interface BRI1/1
description  Ecotel EMPE N:
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/2
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/3
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/4
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/5
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/6
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/7
no ip address
isdn send-alerting
isdn static-tei 0
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip rtcp report interval 500
ip access-list extended BLOCK
deny   ip any host <<omitted>>
permit ip any any
ip radius source-interface GigabitEthernet0/0
radius-server host <<omitted>> auth-port 1647
radius-server host <<omitted>> acct-port 1647
radius-server key <<omitted>>
radius-server vsa send accounting
control-plane
voice-port 0/0/0
translation-profile incoming INLINE_EMPD
translation-profile outgoing OUTLINE_EMPD
compand-type a-law
cptone PT
voice-port 0/0/1
compand-type a-law
cptone PT
voice-port 0/1/0
translation-profile incoming INLINE_EMPA
translation-profile outgoing OUTLINE_EMPA
compand-type a-law
cptone PT
voice-port 0/1/1
translation-profile outgoing OUTLINE_EMPA_NT_FAX
compand-type a-law
cptone PT
voice-port 0/2/0
translation-profile incoming INLINE_EMPB
translation-profile outgoing OUTLINE_EMPB
compand-type a-law
cptone PT
voice-port 0/2/1
compand-type a-law
cptone PT
description Ligacao Acesso GSM
bearer-cap Speech
voice-port 0/3/0
translation-profile incoming INLINE_EMPE
translation-profile outgoing OUTLINE_EMPE
compand-type a-law
cptone PT
voice-port 0/3/1
compand-type a-law
cptone PT
bearer-cap Speech
voice-port 1/0/0
compand-type a-law
cptone PT
voice-port 1/0/1
compand-type a-law
cptone PT
voice-port 1/0/2
compand-type a-law
cptone PT
voice-port 1/0/3
compand-type a-law
cptone PT
voice-port 1/0/4
compand-type a-law
cptone PT
voice-port 1/0/5
compand-type a-law
cptone PT
voice-port 1/0/6
compand-type a-law
cptone PT
voice-port 1/0/7
compand-type a-law
cptone PT
voice-port 1/0/8
translation-profile incoming INLINE_EMPC
translation-profile outgoing OUTLINE_EMPC
compand-type a-law
cptone PT
voice-port 1/0/9
compand-type a-law
cptone PT
voice-port 1/0/10
compand-type a-law
cptone PT
voice-port 1/0/11
compand-type a-law
cptone PT
voice-port 1/0/16
compand-type a-law
cptone PT
voice-port 1/0/17
compand-type a-law
cptone PT
voice-port 1/0/18
compand-type a-law
cptone PT
voice-port 1/0/19
compand-type a-law
cptone PT
ccm-manager music-on-hold
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp profile default
dial-peer voice 1 pots
description +++++ Dial-peer +++++
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 10 pots
description touchwise
destination-pattern 1T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0
dial-peer voice 20 pots
description globalmove
preference 1
shutdown
destination-pattern 5T
port 0/1/0
dial-peer voice 30 pots
description globaltemp
shutdown
destination-pattern 3T
port 0/2/0
dial-peer voice 40 pots
description EMPE
destination-pattern 4T
port 0/3/0
dial-peer voice 100 voip
preference 1
destination-pattern .
session target ipv4:10.35.2.1
voice-class codec 1
no vad
dial-peer voice 21 pots
preference 2
shutdown
port 0/1/1
dial-peer voice 101 voip
preference 2
session target ipv4:10.35.2.2
voice-class codec 1
no vad
dial-peer voice 24 pots
preference 1
destination-pattern 59[1236].......
port 0/3/1
forward-digits 9
dial-peer voice 25 pots
preference 1
destination-pattern 500T
port 0/1/0
dial-peer voice 26 pots
preference 2
port 0/1/1
dial-peer voice 27 pots
preference 1
destination-pattern 5[123678]T
port 0/1/0
dial-peer voice 28 pots
preference 2
port 0/1/1
dial-peer voice 34 pots
description globalTemp
preference 1
destination-pattern 39[1236].......
port 0/2/1
forward-digits 9
dial-peer voice 35 pots
preference 1
destination-pattern 300T
port 0/2/0
dial-peer voice 37 pots
preference 1
destination-pattern 3[123678]T
port 0/2/0
dial-peer voice 14 pots
description empd
preference 1
destination-pattern 19386648.......
port 0/0/1
forward-digits 9
dial-peer voice 15 pots
description empd
preference 1
destination-pattern 19365483.......
port 0/0/1
forward-digits 9
dial-peer voice 16 pots
description empd
preference 1
destination-pattern 19341347.......
port 0/0/1
forward-digits 9
dial-peer voice 50 pots
description EMPC
port 1/0/8
gateway
timer receive-rtp 1200
gatekeeper
shutdown
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.35.2.250 port 2000
max-ephones 100
max-dn 300
transfer-pattern 09........
transfer-pattern 02........
transfer-pattern 0.........
transfer-pattern 000T
transfer-pattern 4...
keepalive 10
time-format 24
date-format dd-mm-yy
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login authentication touchwise
transport input ssh
line vty 5 15
transport input ssh
scheduler allocate 20000 1000
ntp master 5
end
Everyone's tags (4)
Hall of Fame Super Silver
What is the BRI status?  "Sh isdn status"?
Can you post "debug isdn q931" and "debug voice dialpeer"
Chris
Community Member
If t i "Translation Pattern Configuration" switch to another "Partition" existing or internal it works.
If change back for the new i create. It does not work.
So I must be some flaw  i made in Cisco Unified CM.
1063
