Problem with CDR Records relecting
Hi All
I am facing an issue with fetching the CDR records in CCM 4.2. when we login to the CAR tool and trying to fetch the reports on an extension basis and device report basis there is an error diplaying that records not found.
I have attached the screen shot for your reference.
So, i followed the guidelines according to cisco to troubleshoot.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml
I tried all the causes, but i get the same error.
Pl do suggest us solution to fetch the records.
Karthik Sridharan
  • Unified Communications Applications
Re: Problem with CDR Records relecting
are all phones and users already associated??
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Jaime...
Ya... Actually it was an ongoing setup and devices were already associated. We can able to fetch records till April 11, 2008. But after that period, it is giving error.
Hi Jaime/Rob
Can u pl suggest some solution...
Karthik
119
