Community Member
Problem with CFNA
I have a situation where a call handler
is used to route calls. If the call comes
through a gateway the call is passed to the individual. If the phone is busy the
call is dropped. If it is no answer the call goes to voicemail where it should go. Internal calls work just fine. Any thoughts??
Re: Problem with CFNA
what type of PBX are you using? callManager or CCME?
if callManager or CCME, then verify the CNFA settings including the callingSearchSpace if CCM.
also, if CCM, capture some traces while attempting the CNFA to see exactly what CCM is doing with the call for starters and let us know what you find.
if you need assistance with gathering traces, please see the link below:
Community Member
We have callmanager 4.1.(3)SR3. the cfna
and cfbusy are set to voicemail(checkbox) and
use the default vm profile. It works as it
should on both, on internal calls. If an external call comes in and sub is on phone
the call is dropped. Will try some calls
after hours to see if traces can tell me what
is happening. Thanks for the response
