Showing results forĀ
Search instead forĀ
Did you mean:Ā
problem with TFTP server when upgrade CUE
I have router 2811 with AIM-CUE Card I have to Upgrade this CUE from 3.2 to 7.01
When I try to copy by useing commond Software download clean url ftp://10.10.10.2/cue-vm-k9.nm-aim.7.0.1.pkg
give me
Downloading ftp cue-vm-k9.nm-aim.7.0.1.pkg
Download error
Can not download cue-vm-k9.nm-aim.7.0.1.pkg
error code 0 : error type 'couldn't connect to host'
Although I can ping tftp server 10.10.10.2 from cue and vice versa
se-192-168-100-10.localdomain> ping 10.10.10.2  -------------------------------> tftp server
PING 10.10.10.2 (10.10.10.2) 56(84) bytes of data.
64 bytes from 10.10.10.2: icmp_seq=1 ttl=126 time=0.701 ms
64 bytes from 10.10.10.2: icmp_seq=2 ttl=126 time=0.499 ms
64 bytes from 10.10.10.2: icmp_seq=3 ttl=126 time=0.457 ms
64 bytes from 10.10.10.2: icmp_seq=4 ttl=126 time=0.440 ms
64 bytes from 10.10.10.2: icmp_seq=5 ttl=126 time=0.404 ms
interface Loopback0
ip address 192.168.100.1 255.255.255.0
interface Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 192.168.100.10 255.255.255.0
service-module ip default-gateway 192.168.100.1
Is there anything I have to do?
Akaff
kking2008
kking2008
You're gonna need an FTP server, TFTP will not work with CUE upgrades.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/upgrade.html#wp1148118
rizwanr74
Level 7
Level 7
delete your existing TFTP Server and try with this:
http://tftpd32.jounin.net/download/Tftpd32_SE-4.00-setup.exe
Rizwan Rafeek
Hi rizwanr,
I checked,
It's same
Thank you for replaying
Thank you KKing 2008
That was the problem I download FTP Server and it is work fine
Thanks all.
