Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with uc-locale-en_GB-8.6.2.1-12.cop selection on unity connection cluster
Hi All,
Hopefully someone can help me out. I'm trying to install uc-locale-en_GB-8.6.2.1-12.cop on our unity connection cluster which is running 8.6.2.20000-2. The cop files successfully installs and I've rebooted the both servers but I cannot select the language anywhere in unity connection administration.
I suspect this is because I'm running 8.6(2a) from the cisco site and not Unity Connection 8.6(2) Engineering Special 12 as per the release notes for Unity Connection 8.6(2a). Are Cisco likely to release language packs for version 8.6(2a)? Otherwise I guess I'm going to have to try and raise a TAC call and get access to the engineering special so I can gain the british langauge back again.
For reference :-
admin:show version active
Active Master Version: 8.6.2.20000-2
Active Version Installed Software Options:
ciscocm.refresh_upgrade_v1.1.cop
cm-locale-en_GB-8.6.2.1000-1.cop
Mike
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hi All,
Please see the response from Cisco TAC below
"The reason you are still not able to select GB as the default language is because Connection 8.6.2 version of languages other than ENU are released but these locales work with Connection 8.6(2) Engineering Special 12 version.
Supported Document-->
Installing Additional Cisco Unity Connection Languages
http://tools.cisco.com/squish/2037E
Your current version is 8.6(2a) and therefore, you will have to install ES12 to get the locales compatible with CUC version. Please let me know your CCO ID and I will publish ES12 for you as it is not available on CCO yet."
Colin
Hall of Fame Super Red
Hi Mike,
I'm not sure about the versioning, but  am curious if you followed these steps;
To Install Connection 8.x Language Files from a Disc
Step 1 Stop the Connection Conversation Manager and Connection Mixer services:
a. Start Cisco Unity Connection Serviceability.
b. From the Tools menu, select Service Management.
c. Under Critical Services, in the Connection Conversation Manager row, select Stop.
d. Wait for the service to stop.
e. Also under Critical Services, in the Connection Mixer row, select Stop.
f. Wait for the service to stop.
Step 2 Insert the Languages disc in the disc drive.
Step 3 Sign in to Cisco Unified Operating System Administration.
Step 4 From the Software Upgrades menu, select Install/Upgrade. The Software Installation/Upgrade window appears.
Step 5 In the Source list, select DVD/CD.
Step 6 In the Directory field, enter the path to the folder that contains the language file on the CD or DVD.
If the language file is in the root folder or if you created an ISO image DVD, enter a slash (/) in the Directory field.
Step 7 To continue the language installation process, select Next.
Step 8 Select the language that you want to install, and select Next.
Step 9 Monitor the progress of the download.
Step 10 If you want to install another language: Select Install Another, and repeat Step 4 through Step 9.
If you are finished installing languages: Restart services:
c. Under Critical Services, in the Connection Conversation Manager row, select Start.
d. Wait for the service to start.
e. Also under Critical Services, in the Connection Mixer row, select Start.
f. Wait for the service to start.
g. If you installed Japanese: Run the CLI command utils service restart Cisco Tomcat to restart the Tomcat service.
Note Make sure that the multilingual .cop files are installed on the exact specific CUC build that they were created for. Applying incorrect .cop files for your specific version results in an unexpected behavior of the user conversations.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug027.html#wp1054157
Cheers!
Rob
Hi Rob,
I did follow that procedure and also restart the servers after installing the language pack. I also tried using the CLI to delete the locale and then added it again as above with a restart just for good measure.
Still no luck though :-(
Mike
Hi Mike,
Bummer!
I just wasn't sure if you had shut down the Connection Conversation Manager and Connection Mixer services
before starting. I guess you are right.....time for TAC. Seeing that 8.6.(2) is deferred the 8.6(2a) locales
should be available I would think.
Sorry I couldn't have been more help here
Cheers!
Rob
PS: please let us know how you make out.
Thanks Rob. I'll write an email to our supplier as heaven forbid an end user talk to Cisco directly in the UK. I'll let you know how I get on.
Rob,
Where do you see that 8.6.2 is deferred?  8.6.2 Connection is still downloadable, no mention of an ES.  But, the locales have definitely changed.  I downloaded just prior to 1/17/12 and had no issue.  My locales are version and did not require ES12, so something happened as they are not visible anymore, but there is no deferral note, either.  Do you know something?  I happen to have a failed cluster with UK English right now, so may be a clue.
Stephanie
Hi Mike,
We have exactly the same problem with CUCM Business Edition 5000. I might log a call with TAC tomorrow unless someone can come up with the solution before then. If I get a solution from TAC I will post it up here.
Cheers
Colin
I meet the same issue with FR locale and using CUC version 8.6.2.20000-2.
Does somebody know what version is Unity Connection 8.6.2 ES 12 because we can download only 8.6.2 or 8.6.2(a)?
Thank you
I have logged a TAC case with Cisco regarding this. I will post the results here as soon as I get them.
Colin
Hi All,
Colin
Cisco have also responded saying that we need to upgrade the ES12 as above. I've scheduled a change for the 11th of Feb to upgrade and try the locales. If Anyone trys it before please tell me how you get on!
Hey Colin & Mike,
Thanks for posting back with your updates to this good thread +5 each
This type of follow-up really helps others here @ CSC!
Cheers!
Rob
Hi Mike,
Just installed the ES 12 Upgrade and installed the locale file. Everything now working fine and back to UK English on Unity Connection. Hope your upgrade goes OK.
All the best
Colin
Gold
Hi Colin
Good news and thanks for the feedback. I've been postponing upgrades from 8.6(1) for this reason.
I do understand that locales take time to put together but I wish someone at Cisco would realise that this stuff is really important to us poor souls that live and work outside of the US - this release has been hugely painful and it's a tough sell to customers who spend huge amounts of money on maintenance to tell them we can't upgrade as the locales aren't available / don't work.
Now if only someone in the Speech Connect / voice enabled directory handler team would finally realise that locales would be really nice too. I've only been waiting getting on 3 years for these......
Barry
Hi Barry,
I would agree. I don't know why on this occasion Cisco released the locale files for an engineering special without the ES12 software being generally available for download. I cannot see the locale file being significantly different between 8.6(2a) and the ES12, so it would have made sense to release for both. At least customers would be able to have a fully functioning system for 8.6(2a) and could get ES12 if required for bug fixes. The software should really be released as a complete package. I will make sure that in future, I don't apply any software upgrades until all the files are available.
Good Luck
Colin
Thanks for the update Colin. Can't wait to get rid of the american voice now!
I've recently encountered the same problem with CUC version 8.6.2.20000-2 and the GB locale file.
I tried following the procedure detailed by Rob and installed ES12 then restarted the services.
Unfortunately this didn't work for us, the locale file was appearing in 'show version active' command but it wasn't available to select in the GUI.
Tried uninstalling the locale and re-installing but still had the same issue.
When ES12 is mentioned above are you refering to a locale release only or is ES12 also a CUC release?
I am dealing with Cisco craziness right now.  You have to upgrade CUC to ES12 first.  I would recomment that you uninstall any NON-ES 12 locales first as if you have a cluster, the CUC ES12 install will fail on the subscriber only.
After you install CUC ES12, then install the ES12 locales.
You will need to open a TAC case to obtain CUC ES12 - as of yesterday it was not posted to CCO. .;..totally confusing, huh?
Good luck,
Stephanie
Thanks Stephanie, I got pretty confused thinking that ES12 only refered to a locale version and miserably failed getting it to work with 8.6.2.20000-2.
We had to roll back to 7.1.3 in the end but I'm sure we'll try again in the near future as soon as we can obtain the correct version from TAC.
Mark
We upgraded Unity connection 8.5 to 8.6 ES12 to get the French Locale.
Unity connecton version:  8.6.2ES12.21007-12
UC Locale: uc-locale-fr_CA-8.6.2.1-12.cop.sgn
The ugprade went fine and we installed the French Locale successfully. The cli "show cuc locales" showed the locale correctly but Unity connection GUI didn't show the French locale installed.
We followed the instructions to install locale (stop connection mixer and connection conversation manager) but no good. We restarted the server but had same issue.
Contacted TAC and they told us about the following BUG. They advised us to uninstall the locale, upgrade to Unity connecton version:  8.6.2a SU1 and install the locale again.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtt21815
HTH.
thanks,
Kapil
Hall of Fame Super Silver
Notice that Cisco just released new locales 8.6.2.1-25 available for publically available UCON 8.6.2aSU1. The other day I loaded GB, French and Spanish sucessfully.
HTH,
Chris
3136
