Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problems with Mobile Message Access for BlackBerry
MMA is working for most of my users but two.
One of them get the "cannot change number" message when trying to change the phone # and password on the blackberry.
The second one is able to change the number and click on the link but his phone never rings.
I'd appreciate any pointers on where to look for troubleshooting info.
I looked in the blackberry and unity event logs but couldn't find any relevant information
Re: Problems with Mobile Message Access for BlackBerry
There is an open defect CSCse04439, however I think this would impact all users that try to change the phone number. Here is the information on that defect, if you don't see the DCOM errors in the system log, it's likely a different issue:
Symptom:
When using the Unity Mobile Message Access, you enter your pin and the number to call then you receive a message stating:
Unable to change#
Unknown error 80070005
You will also see DCOM errors in the System Log which have a description similar to:
machine-default Local Activation {60EB7702-6A7A-11D1-8029-00C04FAD610B} IUSR_
Conditions:
Unity 4.1(1) or later using Mobile Message Access
Workaround:
Go into Component Services and give IUSR_ access to AvCsGateway.
As for the issue where the one user's phone never rings...there have been issues reported with some (older?) Blackberries where the device does not allow simultateous data out communication and phone call in. So the call goes straight to voicemail and never rings the phone. You can use Port Status Monitor tool to see if an outdial is generated, and if so whether it is sent to voicemail.
I have somewhat of the same situtation to this and any help would be appreciated prior to opening a TAC case. The first 2 users we setup on Mobile Messaging worked fine. Clicked the link and were able to setup their Unity password and callback number. Worked fine. Since then, all users I try to setup get the 80070005 error, Unable to change #. No DCOM errors on the system logs, etc. Any other thoughts?
It seemed that we were hitting bug
CSCsd65847
The bugfix is available in Unity 4.2(1) ES79.
127
