Problems with Unity Express v1.0.2
Greetings. This is my first go with CUE v1.0.2, and it's running on a 3745 (12.3(4)T4) with CCME v3. The CCME installation is running like a champ, no problems. At issue is the CUE operations. I place a call from one phone to another phone, let it time out, and the call goes to voicemail just fine. But, I then get a message "I'm sorry the system is experiencing difficulties......" and the voicemail session ends.
In my debugs, I see the following:
APP_LOADED:Application loaded: Application=voicemail
Apr 09 12:34:29 10.200.53.2 Apr 9 12:33:18 localhost java: INFO ccn StackSip DBUG PROTOCOL_MSG:Protocol Stack Message: Stack Message=Register: registerExpires = 0, no registration will be done
Apr 09 12:34:29 10.200.53.2 Apr 9 12:33:18 localhost java: ERROR ccn SubsystemSip DBUG SS_OUT_OF_SERVICE:SIP subsystem in out of service: Failure reason=
Apr 09 12:34:31 10.200.53.2 Apr 9 12:33:21 localhost ccn: INFO ccn server output WFWorkflow::preprocess - Entering....
Apr 09 12:34:32 10.200.53.2 Apr 9 12:33:21 localhost ccn: INFO ccn server output WFWorkflow::preprocess - Exiting....
Apr 09 12:34:32 10.200.53.2 Apr 9 12:33:21 localhost java: INFO ccn ManagerAppl DBUG SCRIPT_LOADED:Script loaded: Script=aa.aef
Apr 09 12:34:32 10.200.53.2 Apr 9 12:33:21 localhost java: INFO ccn ManagerAppl DBUG APP_LOADED:Application loaded: Application=autoattendant
Apr 09 12:34:32 10.200.53.2 Apr 9 12:33:21 localhost java: INFO ccn StackSip DBUG PROTOCOL_MSG:Protocol Stack Message: Stack Message=Register: registerExpires = 0, no registration will be done
I'm also getting a console message that says the call timed out before the application could answer.
Here's the CUE config below, thanks for any hints.
se-10-200-53-2# sh run
Generating configuration:
! Timezone Settings
clock timezone America/New_York
hostname se-10-200-53-2
! domain name
ip domain-name localdomain
ntp server 10.200.50.1
groupname Administrators create
username admin create
username admin phonenumber "1000"
groupname Administrators member admin
backup server url "ftp://127.0.0.1/ftp" username "" password ""
ccn application autoattendant
description "autoattendant"
enabled
maxsessions 4
script "aa.aef"
parameter "MaxRetry" "3"
parameter "operExtn" "0"
parameter "welcomePrompt" "AAWelcome.wav"
end application
ccn application ciscomwiapplication
description "ciscomwiapplication"
enabled
maxsessions 4
script "setmwi.aef"
parameter "strMWI_OFF_DN" "1090"
parameter "strMWI_ON_DN" "1091"
parameter "CallControlGroupID" "0"
end application
ccn application voicemail
description "voicemail"
enabled
maxsessions 4
script "voicebrowser.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn subsystem sip
gateway address "10.200.53.2"
gateway port 5169
end subsystem
ccn trigger sip phonenumber 1093
application "autoattendant"
enabled
locale "en_US"
maxsessions 4
end trigger
ccn trigger sip phonenumber 1098
application "voicemail"
enabled
idletimeout 10
locale "en_US"
maxsessions 3
end trigger
log console errors
log server 10.200.52.100
voicemail default expiration time 21
voicemail default mailboxsize 3600
voicemail default messagesize 180
voicemail mailbox owner "admin" size 3600
description "admin"
expiration time 30
messagesize 60
end mailbox
end
se-10-200-53-2#
se-10-200-53-2#
Thanks,Jeff
266
