Publisher Problem.
Dear All
I am in a big trouble. I have CCM Subscriber 5.1.3.1000-12. My issue is my publisher that had the same version had crashed. Now I am trying to reinstall it, but the problem is I have the media of 5.1.2 so it's not joining my Subscriber as a second node just because of conflict of my versions. I also tried to patch it at the time of installation with 5.1.3 but it's not taking the patch I don't know why. Can anyone help me out in this? …
Please .. thanks in advance
Best regards,
Fahad
Re: Publisher Problem.
Hi Fahad, if you reinstalled the publisher you also have to reinstall the subscriber. This link will help you:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/5_1/clstr513.html#wp87717
That version of CCM it's old, you should think about to apply the last SR or upgrade to version 6.1 or 7.X.
Ricardo
Dear Ricardo
Thanks for your reply, i just want to know, is there any way to install my publisher without doin reinstall my Subcriber?
Waiting for your reply
Again Thanks
Fahad
126
