QoS for LAN Extension
Hi, all,
I am looking for Cisco Doc about designing QoS for LAN Extension as WAN architecture. Since LLQ is not an option in this case, how can I prioritize voice traffic?
Many thanks.
1 REPLY
Super Bronze
Re: QoS for LAN Extension
With LAN extensions you typically terminate the circuit on a L2 switch (thereby extending a single LAN subnet) or an L3 switch (thereby making it a routed connection)... My preferred approach is the second one.
Either way you need to use switch QoS - which can be quite different depending on what switches you have... read the SRND on QoS, in particular sections on Campus QoS most of which can be used in your situation...
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Aaron
Please rate helpful posts....
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
225
作成コンテンツを作成するには してください
