Re: Echo between extension calls and extension and PSTN Calls
I have CUCm 6.0.1 installed and I am experiencing intermitent echo on calls between extensions and calls to the PSTN. Also i am having intermittent dropped calls with PSTN calls? Can you advise how to resolve these problems?
Re: Re: Echo between extension calls and extension and PSTN Call
Check whether or not you are getting errors on the T1s for voice and data (if dialing between extensions). Check for errors on the controllers and interfaces. Path code and line code violations are not good when it comes to voice.
This is the output of the status on the T1
1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060707, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (354 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
46 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
46 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
15 Line Code Violations, 26661 Path Code Violations,
11098 Slip Secs, 0 Fr Loss Secs, 6 Line Err Secs, 47 Degraded Mins,
11482 Errored Secs, 428 Bursty Err Secs, 34 Severely Err Secs, 0 Unavail Se
105
