Regarding CDR Analysis and reporting login problem
We are having Cisco Call Manager 4.1 .
When we login to CAR its showing error as " Invalid User ".
Now we are able to login with same username and password previously.
Can u pls help how we can now able to login to CAR?
Vaishali
Red
Re: Regarding CDR Analysis and reporting login problem
CallManager keeps record of which user would be the CAR admin user.  This is in DC Directory (or AD if your CCM is AD-integrated).
Editing the directory is not recommended by end users.  Please open a TAC case.  They should be able to recover it in 5 minutes.
Michael
http://htluo.blogspot.com
Try this
Cisco CallManager: Restoring a Lost  ART / CAR Password
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801115eb.shtml#topic1
The procedure for AD is quite similar, if you don't feel comfortable doing this reach TAC.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
We are having problem with CDR not getting generated at all.
In Error log its showing Database access error.
While uninstalling CAR , Its not able to uninstall DC Directory.
Also when we open DC Directory Admin we are not able to delete "CiscoAdminRepToolAdminGroupUsers "
under "Groups" tab.
So we are not able to login with default admin user.
Its showing error as " you are not authorized " while deleting "CiscoAdminRepToolAdminGroupUsers"
We are logging with local administrator.
Please let us know how we can do this so that we can login with default user
Vaishali
249
