Replacement belt clip for the 7925g leather case
We've broken/lost some belt clips for the leather cases for our 7925g.  The cases are pretty expensive to purchase just for the clips.  Does anyone know where I can buy some replacement or compatible ones?
Please check with the Cisco Partner Helpline (PH) team, by opening a case with them.
please use www.cisco.com/go/ph to do so.
Hope it helps.
Anand
Please rate helpful posts !!
Hall of Fame Super Red
Hi David,
Just to add a note to the good tips from Anand (+5 "A" )
Just plug;
CP-CLIP-7925-CASE
into your fave search engine and you'll get lots of
hits. Looks like about $70US for a pack of 30 on average
Cheers!
Rob
698
