Community Member
RP not registered on IPCC 4.0(3) with CCM 4.1(3)
I was integrating IPCC 4.0(3) with CCM 4.1(3).I added jtapi trigger without any errors but when I check RP status on CCM ,I found that it is not registered in spite of It was associated with jtapi user
Any ideas??
Re: RP not registered on IPCC 4.0(3) with CCM 4.1(3)
check the pwd on both sides, restart CTIManager
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
You mean JTAPI password ?;it is created by CCM automatically
101
