Community Member
Same PIN in Unity and UCM
is it possible the keep the PIN in Unity and UCM synchronous?
Re: Same PIN in Unity and UCM
No, the directory from CUCM and Unity is not connected and does not replicate information between them.
The only way is to manually change both to the same.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
ok, so i've read it's possible to change the PIN in the sql database. Does anyone know, in which database and table?
Community Member
is it possible between "unity connection 7.x" and "ucm 7.x"?
If not, is it possible to change the PIN in unity connection by axl? So, then i could change the pin in both systems with an external application?!
215
