Secondary dialtone replacement number for 9 ?
We have subscribed for a SIP Trunk to PSTN (service provider) .
The range is 38499300 -38499599 , so the DIDs are 9300 - 9599.
So the Internal Extensions are to be 9300 - 9599 , starts with '9" ,
i can not use 9 for secondary dialtone. which is the best replacement
or solution for this ? Can i use # , * etc to get outside dial ?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Secondary dialtone replacement number for 9 ?
2 solutions:
Translate the DID to different internal extension.
Or use another digit for off net access code.
Chris
2 solutions:
Chris
Thanx Chris ,  Can you confirm if i can use symbols like " # " or " * "  instead of 9  to avoid translations ?
Sure, though it may take some time got users to adjust.
Chris
121
