11-19-2009 05:40 PM - edited 03-19-2019 12:01 AM
Anyone one have TAPS running on the UCCX 7.0.1sr4/UCM 7.1..3 ?
I have downloaded the plugin from UCM and installed on UCCX. I have loaded the TAPS AAR.AAR with AAR Manager. The TAPS Application is listed but if you open the Application get an error "Error occured while loading The SCRIPT[TAPS.aef]. Check log for details.
Mike
Solved! Go to Solution.
11-20-2009 08:48 AM
After you run setup, you have to log into the UCCX server and
go to Applications, add new, add the TAPS script.
Setup a trigger for the taps app and it should work.
To me, it looks like the script is the same from 6.x to 7.x. I have a UCCX run on VMWare that I move from cluster to cluster to do installs and have not had to update the TAPS script on my uccx server.
What steps are you doing?
11-20-2009 08:35 AM
Yeah, that EXE file has been broken for awhile. THe work around I found is if take the exe file and unpackage it to the UCCX server. It will unpackage two files.
issscript and setup.exe.
I only run the setup.exe and it installs the TAP application fine on my UCCX server. Something in the script install does not work.
Good luck! I think WINRAR will unpackage the EXE file for you (or any other app you can find)
11-20-2009 08:43 AM
Thanks for the reply.
I tried unpacking last night with the same behavoir.
We there additional steps? I deleted the Application, Removed the TAPS AAR.AAR and Removed the Taps.aef. Ran the both files.
I see you are saying to just run the setup though?
Thanks again,
Mike
11-20-2009 08:48 AM
11-20-2009 10:41 AM
Followed your steps and issue is resolved. Thank you for the great
fix!
Steps after installation failed.
Uninstalled TAPS
Removed TAPS AAR.AAR files
Removed TAPS.AEF File
Removed Application from APPADMIN
Remove Taps.AEF from Scripts/APPADMIN
Extracted files from TAPS plugin
Ran Setup.EXE
Added TAPS AAR.AAR from AAR Management/APPADMIN
Edited the TAPS.AEF to add trigger
Restarted Nodes - HA system
07-01-2010 04:17 PM
I am experiencing the exact same presentation with CUCM 7.1.3 and UCCX 7.0.1 Build 168.
I have followed the steps in the previous post exactly, but still get the error message about the script when I open the TAPS application.
I've looked over the script, but I don't really understand the Java and/or database references. I'm used to writing scripts to control call routing - I wouldn't recognize a bad reference here if it bit me. I tried poking around in the application logs to see if I could find a more detailed reference as to why the UCCX application doesn't like the script file. Again, I was in way over my head just trying to find the log file that might give me the clue.
Does anyone have an updated TAPS.aef script that works? Should I maybe just hang a trigger on the application to see if it works regardless of the reported error? I can't imagine that no one is using or has used TAPS with this product combination.
EDIT: Okay, so I made a rookie mistake. After opening the script in the CCX Editor, validating it, then saving it, all worked as advertised. Of course, looks like no one was watching this thread anyway...
08-10-2010 03:36 AM
Did you have to install TAPS on both servers as in the case of HA??
10-04-2010 12:55 PM
Do we know what exactly needs to be edited on the TAPS.aef to make this work?
10-04-2010 02:35 PM
One user above reported having to edit the .aef with accurate trigger information. I don't recall having to do that. It was simply opening the script in the editor, validating it, saving it and uploading the validated file that got this service working for me.
10-04-2010 02:41 PM
it worked for me after restarting the CRS Administration from Control Center
10-05-2010 12:27 AM
After much rebooting, deleting etc I got TAPS to work on UCCX 7 with CUCM 6.1 I initially installed the TAPS via the plug in but the install worked but TAPS itself failed to work. I then installed it via extracting the file and running the .exe. I then copied across all the prompts, redone them for European and created a new folder called TAPS for EN_GB, reconfigured the application to use EN_GB but that also failed. We then "turned" on EN_US, changed the language to have US as an option assigned the prompts/Application to it and then assigned the language support in CUCM for TAPS to US - all working. As a UK company we tried to use TAPS under the English but had to use US- hope it helps
I don`t know if I installed it via the plug in and use the US langauge from the start whether that would have resolved but I did not want to remove TAPS afer getting it to wpork to prove it
