05-21-2008 04:13 AM - edited 03-18-2019 08:58 PM
Hi all,
due to troubleshooting issue over Unity,
we are looking for a way to follow step by step packets route between a test Ip Phone and Unity itself.
So, is there any workaround to perform a sort of tracert command using phone directly ? In this way could be possible to follow packet route from origin to endpoint.
Thanks in advance
Federico
05-21-2008 04:39 AM
Not that I have every heard of. I would just trace route from the default-gateway of the phone and source the trace from the same subnet the phone resides in.
05-21-2008 06:01 AM
get a sniffer trace. that will show you all the traffic to and from the phone
javalenc
if this helps, please rate
05-23-2008 03:39 AM
well, sniffer already used..
but you can see only packet with source and destination addresses related to the end-points and not which are the middle-hop between ip phone and Unity.
This is the reason why we are looking for a way to simulate tracert command.
06-02-2008 11:22 AM
Get laptop connect to port change port access Vlan to voice Vlan and then try to do the tracert .
06-02-2008 10:33 PM
I'll try and give you a feedback.
Federico
