Community Member
Transfer from a users vm box to a route point in CM
Is it possible to give a caller an option during a voicemail greeting to press #1 and the system route them to a predefined number within Call Manager, say a route point?
Unity 4.0.4
1 ACCEPTED SOLUTION
Re: Transfer from a users vm box to a route point in CM
yes, configure caller input.
create a dummy call handler and under transfer options set it to, yes, calls subscriber at this number and type in the number you want to reach
on the subscriber configure caller input X to attempt transfer to dummy call handler
make sure restrictions tables allow this and the that the CSS of VM ports can reach the number
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
javalenc
java
Community Member
That worked perfect! Thanks!
121
