Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
transfer from hunt pilot to call handler- unity connection
   hello
this is the snario :
call that transfer from call handler  (unity connection)   to  hunt pilot(cucm)  and back to call handler(unity connection)  to specified vm
is not working.
i get the basic vm all the time insted of the greeting of the person i transfer to
helpppppppppp
thanks
shoham
Hall of Fame Super Red
Re: transfer from hunt pilot to call handler- unity connection
Hi Shoham,
Can you explain this portion (with examples if possible);
back to call handler (unity connection)  to specified vm fails
Cheers!
Rob
My guess is he wants to go to the VM from one of the line group members, but since he's dialing the hunt pilot DN you're trying to reach the matching DN in unity.
You can define the DN from HP as alternate extension for subscriber or create a call routing rule to achieve the same.
An example of what you dial, what happens, and what you want to happen would clear things up
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
357
