Community Member
Transfering Calls to PSTN number through a Call Handler
I need to create a call handler and within the caller input allow a caller to press a key to transfer to a PSTN number. Unfortunately it doesn't seem to work. I think it maybe caused by the restriction tables, but I haven't been able to get it to work. Are any of you familar with this type of configuration?
Re: Transfering Calls to PSTN number through a Call Handler
have the caller input from your call handler to send them to a call system transfer. then they can dial anything that the restriction tables allow.
unity by default only recognizes numbers that are defined within the config
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Silver
The way I do this is as follwoing:
create new call hanlder with transfer set to a dummy DN, which is defined in CM as cti port for example
In the AA call handler on the caller input map select this call handler to be invoked upon the appropriate dtmf input.
On the cti port set the call forward all to the external desitination and make sure you apply the proper CSS.
With the above config you do not need to worry about restriction tables in Unity, and you can control which GW will be used for the outboudn call via the assigned CSS to the cti port,etc.
HTH,
Chris
Community Member
Chris,
That works, but the caller ID is that of the voicemail port or the external phone number mask of that voicemail port. I need it to show the original calling number on the destination device's display not that of the forwarding voicemail port. Have you had any luck with that?
I would think that if you do "release to switch" transfer on Unity it should present the original caller id. Is this how you have it?
Chris
170
