Tuning CSA for Unity and CCM 4.X
Has anyone tuned the CSA to allow a third party application to run. I am trying to get a Event Log translator that generates snmp traps to run, and CSA blocks its operation. I understand CSA for these platforms is standalone and specifcally tuned for Unity and CCM 4.X......Can these still be tuned either in the CSA Management platform, and then re-inserted as standalone or locally on the servers ??
1 REPLY
Re: Tuning CSA for Unity and CCM 4.X
Yes, if you're running a CSA Management Center then you can customize your own policies and generate new agent kits, either standalone or managed. Export files are available from the CSA for Unity and CCM 4.x standalone agents. You can use these export files as a starting point for new policies in your CSA MC. Customize the policies as needed then generate new agent kits.
The export file for Unity can be found here:
http://www.cisco.com/cgi-bin/tablebuild.pl/unity3d
Hope this helps,
Eric
100
