Community Member
Two hop method --DIRT
Folks,
I just read the documentation for DIRT. I am confussed.
I want to backup my unity server along with voicemail messages. When i choose two hop method and specify a local directory, the backup goes through, but that directory is empty?
if i do not use the two hop method and try to back up unity what will i not backup???
VIP Purple
Re: Two hop method --DIRT
The only difference is that when you use the two hop method, the SQL backup is first backed up to a local directory and then moved to another location. This comes in handy when you want to backup Unity to a network location. The SQL backup is done using the SQL services and is limited by the permissions of that account. If you want to write the backup file to a location that SQL services do not have access to, you can use the two hop method which uses the account that DiRT is running under to write to the network location
Hope this helps. If so, please rate the post.
Brandon
Community Member
Brandon,
Does that mean that is i see the local pointed directory empty for two hop methos it is normal, the tool automatically moves that stuff to the target location?
yes - after the files are copied to the "remote" location that local directory is flushed.
116
