Setting up a new UC520 and having problem getting the voicemail or autoattendent to work. Inbound and outbound calls to phones other than the AA / VM work fine.
If I run a debug on the call or look at dial peer stats, the peer associated with AA gets a cause code 1 back.
Last Disconnect Cause is "1 ",
Last Disconnect Text is "unassigned number (1)",
Last Setup Time = 171194.
Last Disconnect Time = 0.
The dial peer is getting matched against on the call, but it seems like the integrated service isn't answering the call.
This is the default setup:
dial-peer voice 2000 voip
destination-pattern 501
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
codec g711ulaw
no vad
The same occurance happens whether calling by extension internally, or trying from the world.
I have tried with the factory fresh configuration and just putting in auto attendent configuration, but it behaves the same. It seems like the service just isn't listening of the call.
If I run a debug call it shows the following:
Feb 19 17:22:34.083: //32/176E96148050/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x8547A3D4
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 202
Called Number : 501
Source IP Address (Sig ): 10.1.10.2
Destn SIP Req Addr:Port : 10.1.10.1:5060
Destn SIP Resp Addr:Port : 10.1.10.1:5060
Destination Name : 10.1.10.1
Feb 19 17:22:34.083: //32/176E96148050/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.1.10.2
Source IP Port (Media): 16452
Destn IP Address (Media): 0.0.0.0
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): 0.0.0.0:0
Disconnect Cause (CC) : 1
Disconnect Cause (SIP) : 404
Any thoughts on what is missing?
