03-24-2009 09:36 AM - edited 03-18-2019 10:44 PM
Hello I have a UC520 with only two pots lines for calls in a line hunt. There are no DID's, only the number for the pots line hunt group. I'am using a 4 digit dial plan. What do i have to configure to strip the last 4 digits and send it to unity express for the AA? I already have a dial-peer for the 4 digits pointing to unity express. Do I need to perform a number translation rule to truncate it down to 4 digits, or use a dial-plan? Thanks
03-24-2009 10:00 AM
You can configure the following. This example uses 1234 for the AA DN.
voice-port 0/1/0
connection plar 1234
voice-port 0/1/1
Hope this helps.
Brandon
03-24-2009 10:24 AM
Brandon,
so what will happen here is when the voice-port comes up to recieve a call it will automatically dial my AA extension? What about outgoing calls such a 911 or, this won't have an effect on them right? It's only incoming. I believe my outgoing dial-peers are all correct. Thanks
Jason
03-24-2009 10:24 AM
Jason,
That is correct. No effect on outgoing calls.
Brandon
