UCCX/IP IVR 5.0(2) installation problem
robert_bryl
When I install UCCX 5.0(2)from CD I get monit: "Computer hardware provided by Cisco is required to install UCCX...."
My server configuration is:
DL-320 G4 3,4Ghz
OS Windows server 2003 Enterprise
Cisco Solution Set (compatibility hardware list) including: HP DL320-G4 3,4Ghz)
I don't know where is problem ?
thx
gpulos
Level 8
Level 8
The problem is that the hardware you're using is not a Cisco supplied MCS server, and the CRS install disks know this.
In order to get CRS installed on a non MCS system, it is possible.
Email me if you'd like the exact steps and required software and I can give you ftp access to download them.
ftpaccess@ccieme.com
Hi Greg,
I would be interested in doing these for our lab. Could you help me please in getting through the hardware incompatibility message please?
Thanks a lot in advance,
Chawki
HI Gpulos
Do you stiil have this information tchat you can share with me?
