Unable to add phones using CUCME
I am trying to add new phones using the CUCME graphical interface but the web page just doesnt proceed after I make the changes and hit the submit button.
I captured the following error messages:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; InfoPath.1; FDM; MS-RTC LM 8)
Timestamp: Fri, 26 Nov 2010 16:47:37 UTC
Message: Permission denied
Line: 1
Char: 1
Code: 0
URI: http://192.168.0.1/ITSMain
Here's another one:
Invalid ITS Command
And another:
Trident/4.0; GTB6.6; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR
3.0.04506.30; InfoPath.2; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Fri, 26 Nov 2010 16:24:48 UTC
Line: 1
Char: 1
Code: 0
URI: http://192.168.2.1/ITSMain
Message: 'value' is null or not an object
Line: 7146
Char: 13
Code: 0
URI: http://192.168.2.1/admin_user.js
Can someone please advice on what to do? I'm slowly running crazy here
Please see my telephony service config snippet:
telephony-service
fxo hook-flash
max-ephones 168
max-dn 500
ip source-address 192.168.2.1 port 2000
timeouts ringing 60
system message WELCOME TO NETCO CCME
url services http://phone-xml.berbee.com/menu.xml
url authentication http://192.168.2.3/voiceview/authentication/authenticate.do
load 7912 CP7912080001SCCP051117A
load 7970 TERM70.7-0-1-0s
load 7971 TERM70.7-0-1-0s
time-zone 21
time-format 24
voicemail 29999
max-conferences 12 gain -6
moh music-on-hold.au
web admin system name admin password cisco123
dn-webedit
time-webedit
transfer-system full-consult
login timeout 180 clear 18:00
after-hours block pattern 1 009 7-24
after-hours block pattern 2 080 7-24
after-hours block pattern 3 0. 7-24
directory last-name-first
directory entry 1 30901 name MANAGER TRAINING
directory entry 2 30101 name CHUKWU P.O
directory entry 3 30102 name YAKUBU A.L
directory entry 4 30547 name MUSTAPHA BELLO
directory entry 5 30901 name manager training
create cnf-files version-stamp 7960 Nov 26 2010 15:03:25
Femi
Everyone's tags (3)
Re: Unable to add phones using CUCME
Just to add, I recently upgraded from C3825-SPSERVICESK9-M version 12.4(9)T to 12.4(24)T3
Femi
Hall of Fame Super Gold
The GUI is buggy and limited. Only use CLI for important administration tasks.
That way you will also learn how CME "works:/
Thanks for the response.
I however noticed the problem was with the GUI version, so I upgraded the
GUI to 7.1 and everything worked fine.
Femi
On Nov/26/10 6:05 PM, "p.bevilacqua"
650
