Unity 5.0.1 help
All,
just a quick one regarding unity 5 - it's one of the servers you never need to touch and we've been tasked to re-deploy a new AD DC to it and i've found that
UnityLdapAuthSetup.exe in the commserv directory will setup a new LDAP authentication process...I'm guessing this setup file writes to a file - does anyone know where this file is located?
Or does anyone know if I run this setup will it kill my current unity LDAP server?
Thanks in advance.
  • Unified Communications Applications
1 REPLY
Unity 5.0.1 help
Hi Thomas,
I'm not quite sure what process you're following but you should not need to do anything with Unity along the lines of what you're referring to if you're simply adding a new DC to the environment.  I guess having more specifics about what you're doing and where you plan on ending up would be beneficial.  Here's the documentation about pointing Unity to a new/different DC/GC:
Changing the Domain Controller and Global Catalog Server
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge060.html
Hope that helps,
Brad
205
