10-16-2008 06:44 AM - edited 03-18-2019 09:49 PM
Have a cust using 15 characters for Hostname on the Unity server (new UM install). Everything well until reaching stage where "Configuring Unity for Message store". They are using Exchange 2007, so a file "Ex2k7Script" script has to be run. Uploaded script to actual Exchange 2007 server and ran it. Error populated. The script adds "Unity" to the beginning of hostname. This causes an error. Anyone know how to work around without changing the server hostname?
10-16-2008 07:45 AM
The unity setup will warn you to use 14 charactors, but will let you past with more if it is a distict name.
However Exhange 2007 will not create a mailbox with over 14.
Now way around it.
I had to rebuild.
Randy
10-16-2008 09:40 AM
Thanks Randy, I kind of figured it. I've started the rebuild - thks.
