Unity 5.0 - using 2nd NIC for backup LAN?
Customer has a separate VLAN for backup jobs. Is using the 2nd NIC on a Unity box for this supported?
thanks,
Scott
1 ACCEPTED SOLUTION
Re: Unity 5.0 - using 2nd NIC for backup LAN?
Second NIC is only used for teaming. The team must be setup as Active-passive Fault Tolerance
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00801d1c56.shtml#active_passive
1 REPLY
89
