Community Member
Unity 5 amazing problem
Dear all,
I faced a strange problem with Unity 5 while trying to access the administration page the Voicemail comes down. When trying to call the Voicemail number nothing happen and after 2 seconds the call ends.
Kindly advice what could be the problem.
1 ACCEPTED SOLUTION
Community Member
Re: Unity 5 amazing problem
Yep, definitely sounds like the problem Rob described. I would recommend downloading the latest Server Updates Wizard and running it. It will fix this problem.
114
