Unity 5.x instalation problem
i have service packs for unity 5.0.1 downloaded from web.
I try to start cuspa.vbs file but I got an error: Microsoft VBScript runtime error; Code 800A0035; Error: File not found.
Where the problem is?
Tnx
1 ACCEPTED SOLUTION
Re: Unity 5.x instalation problem
Move the installation files to a root folder such as
D:\unityfiles\*
Something in the fold structure stops the VBS from running I have found. If I have a folder called D:\unity files\disc 2 sp\*
it will bomb out and not run.
If use the first example, it works fine. Your down is probably fine, just change the folder structure.
It sounds like the downloaded file might be corruptes. YOu might want to download another copy.
Tray
D:\unityfiles\*
that was the problem!!
I moved the installation files to the root directory and no it works fine!
Great to hear and glad to be off assistance!
122
