Unity and IPCC SQL question
Hello All,
I have a question in regards to SQL, In the past I have been told that no maintenance was needed on the servers in regards to SQL (backups / reindex) and that it was all automated. Is that statement still correct in version 5 and 7 that we should not worry about the SQL installs on the box?
2.   Because the SQL version is 2000. What are the steps for us to get the versions upgraded to at least SQL05?
I know that with unity you need to go to the cisco site and download the unity upgrades, but for IPCC what do i need to do ?
thank you
1 ACCEPTED SOLUTION
Re: Unity and IPCC SQL question
There is no SQL upgrade that i know of for either product, Unity 8 will be the 1st version that will support SQL 2005
The applicable version of Microsoft SQL Server:
On a system with more than 32 voice ports, SQL Server 2005 Standard Edition or SQL Server 2000 Standard Edition
On a system with 32 or fewer voice ports, SQL Server 2005 Express or SQL Server 2000 Desktop Engine (MSDE 2000)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/requirements/8xcusysreq.html
The requirement would be to upgrade to Unity 8.X
I believe UCCX won't change SQL version (and DB platform) until they release the Linux version which will drop SQL.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
288
