Unity and Unity Connection Licensing
RKha
Dears,
We have Customer purchase Cisco Unity 5 and server 7845-H-2 , after he receive the equipment , he decide to change the implementation , he want to install Cisco Unity Connection 8.x .
I want to ask , if I order new Unity Connection 8.x software ,I will receive Unix operating system with the software , and what will happen with the Unity license , can I use it with Unity connection , knowing that they already have Support to the license .
Jonathan Schulenberg
Assuming you have UCSS coverage you can actually place a PUT order to upgrade directly to Unity Connection with the same license entitlements. Just make sure that the specific MCS server you ordered is compatible (most Unity servers are).
Thank Jonathan for your greate support .
